Aircon control module location?
Old Jan 25, 2025 | 02:28 PM
Russjz's Avatar
Russjz
Default Aircon control module location?
Problem with setting aircon temperatures, screen resets to 25 degrees (celsius) everytime car is switched off.
I suspect control module.
this is probably under the dash, somewhere....
Anybody know location and accessability?
Module looks like the one pictured
Old Jan 25, 2025 | 06:26 PM
tammap's Avatar
tammap
Here yo go.
Old Jan 27, 2025 | 01:57 PM
Russjz's Avatar
Russjz
Thanks, Looks like it just might be accessable with the glove box out.
(hopefully it stays in that position in a right hand drive)
Old Feb 3, 2025 | 08:07 PM
Russjz's Avatar
Russjz
Reasonably easy to get at.
Remove airbag panel.
Remove glovebox.
there is a piece of ducting blocking access, but only held in with one screw.
Swapped module, problem solved.
Old Feb 6, 2025 | 08:19 AM
tammap's Avatar
tammap
Thansk for reporting back!
Old Feb 11, 2025 | 01:41 PM
Russjz's Avatar
Russjz
If the problem happened on one module, chances are it will do it to someone else
. It's an easy fix once you know where the magic box is located.
Thanks for pic.
Manatee44
RX - 5th Gen (2023-present)
Aug 15, 2025 12:36 PM
laoboiGS3
Apr 26, 2012 08:01 PM
pnyboy27
Oct 29, 2007 12:32 AM
