Upgrading amp with JBL
Old Dec 3, 2024 | 02:40 PM
Abo0ud's Avatar
Abo0ud
10th Gear
Default Upgrading amp with JBL
Hello guys
the problem is the original amplifier Mark Levinson is blowing fuses RAD 1 and RAD 2. At the end the amp was blown too. I was advised to replace the original with a new JBL 86280-0C130
Which costs less than buying a used Mark Levinson amp
I was told the JBL lasts more than original and don’t need to cut any wires just need connector to install
what is your advice guys?
Old Dec 4, 2024 | 11:19 PM
SDGSGUY's Avatar
SDGSGUY
I would find out what is causing the blown fuses first. Your current amp may be defective (usually caused by water damage from the rubber flaps rotting out). I would test your system with a known working ML amp. Unfortunately, the JBL amp is only compatible with the base Pioneer system. Even if you didn’t use the fiber optic line on the ML, one of the connectors is different.
Old Dec 5, 2024 | 12:35 AM
Abo0ud's Avatar
Abo0ud
10th Gear
yeah i found out the causing the blown fuses is the amplifier that’s why I’m thinking about changing it
the dealer said he’s gonna connect it and it is totally compatible all channels but I don’t know
Old Dec 5, 2024 | 12:52 PM
SDGSGUY's Avatar
SDGSGUY
The Lexus dealer told you this? Unfortunately, you’ll need to replace it with another ML amp. The JBL amp is “compatible” with the base Pioneer system, but the speaker outputs are slightly different. I’m in the process of upgrading my sound system, so I’ve been experimenting to see what fits.
Old Dec 7, 2024 | 11:28 AM
Russjz's Avatar
Russjz
I have found tha the only real difference between the ML and basic Pioneer is that the Pioneer does not have (I think) two of the smaller speakers. To me, no real difference in sound quality.
If you didn't know, a ML head unit was powered by the Pioneer unit, you would never guess.
Old Dec 7, 2024 | 12:08 PM
Abo0ud's Avatar
Abo0ud
10th Gear
woo that means having Pioneer amp is better. Still hard to find Pioneer Amplifier in my country tho but i’ll try my best if can’t then i might go to the dealer and try JBL amp as the dealer would install it while I’m watching
stopdrpnro
Jan 21, 2026 08:24 PM
Abo0ud
Jan 3, 2026 02:41 PM
SamySalmon
Aug 17, 2021 02:29 PM
kristiness
Jan 30, 2019 02:51 PM
dacecil
Nov 9, 2008 07:18 PM
