2011 high mileage maintenance
Old Apr 30, 2024 | 08:47 AM
StockIsh's Avatar
StockIsh
1st Gear
Default 2011 high mileage maintenance
Hi guys, new on CL, looking for some recommendations. I just picked up a 2011 gs350 donor car for a motor swap project. I was wondering what sort of preventative work I should be considering while the engine is out, and easy to work on. I expect to at least be resealing valve covers, timing cover and oil pan (upper and lower, as I will likely have to modify a little). Anything I should be paying attention to inside the engine while it's open? Any reason to consider replacing timing chain or guides? Any reason to pull heads? I'm not looking to do a full rebuild, but I want to take care of any potential concerns before it gets installed into the new vehicle.
Thanks
Old Apr 30, 2024 | 09:08 AM
ibidu1's Avatar
ibidu1
Water pump, thermostat, reseal the front timing cover, front crank pulley seal
NinJaski
HS 250h Model (2010-2012)
Jun 22, 2022 06:22 AM
Koreatown
IS F (2008-2014)
27
Jan 23, 2019 04:43 PM
sshaikh01
LX - 3rd Gen (2008-2021)
Dec 16, 2015 06:01 PM
speedywa
Jul 13, 2011 08:15 AM
