Upper Control Arms Replacement
Old Mar 23, 2024 | 04:19 PM
DLACam's Avatar
DLACam
Default Upper Control Arms Replacement
Anyone can recommend me a good aftermarket upper control arms? $300 for 1 for OEM is too much. Any good brand you can recommend?
Thank you,
Old Mar 23, 2024 | 06:53 PM
ibidu1's Avatar
ibidu1
What wrong with your upper control arm? On mine I had the upper control arm ball joint go bad. I was able to buy an aftermarket ball joint for pretty cheap and had it pressed in.
If the bushings are bad, maybe you can find and replace just the bushings. I recently bought lower control arm bushing from a company from thailand seems pretty good quality.
Old Mar 23, 2024 | 08:53 PM
DLACam's Avatar
DLACam
My mechanic noticed a play in the bushings, there is a loud clunking knocking, I have brand new struts, struts mounts, sway bar end links, end-links bushings, lower control arms bushings, etc...
Old Mar 24, 2024 | 06:40 AM
ibidu1's Avatar
ibidu1
The bushings last pretty long time, that clunking could possibly from a strut top mount. Did you ever replace them, when you changed out the front struts? They do sell aftermarket bushings that you can press into the oem upper control arms
Old Mar 24, 2024 | 12:33 PM
DLACam's Avatar
DLACam
The arm is still original, strut top was just changed this week, brand new strut and mount KYB, All 4 new struts KYB. My mechanic recommend to just buy the whole control arm instead of the bushings, I was thinking about getting Beck/Arnley, what do you think?
Old Mar 24, 2024 | 12:48 PM
ibidu1's Avatar
ibidu1
B/A are pretty descent! Ive heard good things about them using parts from taiwan. Did you check to see if rockauto was cheaper?
Old Mar 25, 2024 | 12:22 AM
DLACam's Avatar
DLACam
Yes, Rock auto is the cheapest, you can find them there at $49 a piece. I just ordered a pair. Thank you
newgsman
Suspension and Brakes
May 6, 2014 11:26 AM
GS4K
Mar 26, 2010 11:45 AM
Dr. VIP
Jan 23, 2008 12:56 PM
