Weird (engine?) sound
Old Dec 29, 2023 | 05:05 AM
Kraxa's Avatar
Kraxa
2nd gear
Default Weird (engine?) sound
Hello,
I bought GS300 2006, and since that im dealing with this:
And thats how the exhaust sounds:
It only happens when the engine is hot.
Also when im driving and keeping him under about 50 km/h and less it sounds like this:
Sometimes that sound happens when I brake but rarely. Accelerating even a tiny bit or letting the gas off completly silences that for some time. So basically my driving style now when I have to go 50km/h or less is "accelerating until I hit 50,40 etc - letting the gas off - and repeat" to never hear it.
Old Dec 29, 2023 | 09:17 AM
mspearl95's Avatar
mspearl95
yeah that sounds bad. any error codes? how many miles on your car? checked compression?
Old Dec 29, 2023 | 10:38 AM
Kraxa's Avatar
Kraxa
2nd gear
I had check engine error with too rich air-fuel mixture once but after reseting IT never came back. 275000 km, never checked compression but shouldn't that be connected with bad engine performance and problems with engine start? It's a speed demon for me and never had problem with starting even in -10 C temps. It is smoking white quite a lot though.
Old Dec 29, 2023 | 03:32 PM
mspearl95's Avatar
mspearl95
is it steam coming out the exhaust? have you checked to see if you have coolant in your engine oil?
Old Dec 29, 2023 | 08:49 PM
ibidu1's Avatar
ibidu1
Sounds like a lot of knocking! Maybe rod knock? A rod knock can come and go! You really need to put it on a lift while running, and visually that should help determine whats going on. If its a rod knock, maybe you can get away with dropping the pan, and replacing the worn bearings. Thats the easy bandaid fix! If the crank is damaged then you will need a new engine. What mileage did you change your oil at?
You never know, it could be something stupid like a damaged water pump. Goodluck, hope its an easy fix for you
Fizzboy7
Dec 13, 2023 11:04 PM
t100toyota
GX - 1st Gen (2003-2009)
Oct 21, 2021 01:07 PM
Gtgrad95
May 15, 2013 01:33 PM
Ice350
Nov 15, 2011 08:41 AM
gman44116
Nov 20, 2009 10:44 AM
