Sunroof on 2006 GS300 is stuck open & will not close. I have tried the reset holding the buttons down but no luck. I remove the controls panel to get to the Sunroof motor but I don't see any way to close it. I think most cars allow you to close the sunroof with a hex key in case the motor or switch are not working.
Added a few pics.
Any suggestions?
Thank you!
I had issues with my sunroof on an 09 but I found in the owners manual there's a way to close the sunroof with the key from the fob. Put it in the driver side door, turn and hold the left most position and it should start closing (if your sunroof motor still works).
