Shuddering noise in door panel
Hi, I have a 2007 Lexus GS350 and when I'm driving over rougher roads, going over bumps or cracks in the road there seems to be a shuddering noise in the driver and passenger front door panels. It's not really a creak, more like a shuddering almost clapping noise. If anyone has experienced the same issue or has a fix for it, it would be great to know a solution.
If its the door panel/inside trim then did you inspect it for looseness? Could be something stupid as someone leaving something hidden in the pocket. Or a loose screw, so grab the handle and shake it. Has anyone ever open it? Remove it is not difficult, to inspect if something came loose inside
No it hasn't been taken apart before and I actually replaced all the door clips to try to fix the problem. It didn't do anything and the shuddering seems to come from the door panel itself
janmy7
Nov 2, 2021 10:44 PM
Alphaman19
Dec 7, 2020 02:39 PM
