Power cut problems?
Old Dec 31, 2022 | 01:26 PM
BLKGTE's Avatar
BLKGTE
5th Gear
Default Power cut problems?
Hey guys! I have a buddy with a gte swapped gs300, during WOT his car cuts power at around 5500,4500,6000 etc. but immediately comes back into power. Its not the transmission because itll happen during a gear in “manual mode” and then shift perfectly fine. Itll happen multiple times during a long pull. We ruled out a problem with the throttle body, and we believe its either a fuel or a boost cut but we cannot figure out why it would cut. Its a stock aristo motor running on the aristo ecu, low milage. Thank you!
Old Jan 2, 2023 | 10:21 AM
DMPesso's Avatar
DMPesso
I have no knowledge of turbo swaps but I do recall reading someone had this problem and I believe it was the fuel pump or something related to that.
Old Jan 5, 2023 | 06:30 PM
BLKGTE's Avatar
BLKGTE
5th Gear
i appreciate the response!
kvn2jz
Jun 5, 2021 12:51 PM
twoloose
Nov 16, 2012 09:09 PM
pappi23
GS - 1st Gen (1993-1997)
14
Nov 30, 2008 05:15 PM
turbochris
Nov 20, 2007 11:09 PM
