Back-up reverse lights not working
Old Sep 19, 2022 | 11:19 AM
robo's Avatar
robo
Default Back-up reverse lights not working
My 02 back-up light doesn't work. Checking the wiring diagram, it looks simple circuit but I don't know the location of component. Does anyone tell me where J3/J4 juction connector of the below diagram is located? I read somewhere it is said at the driver's kick panel but I cannot located where it is. Attachment is the picture of the connector on driver's side wall and I am not sure if the white connector is correct one and which wire is is connected the back-up light
Old Sep 19, 2022 | 12:32 PM
Raven01750's Avatar
Raven01750
I'll be able to check for you later on tonight. Do you have a meter? Have you checked voltages at the lamp socket?
Paul
Old Sep 20, 2022 | 02:41 PM
dwoods801's Avatar
dwoods801
It’s probably a couple burned out bulbs, the reverse lights are like brake lights, designed to be on if there is a problem with the switch. I don’t think there is a warning light for a burned out reverse light. So unless the wiring was damaged somehow, probably just need a 2 pack of 921 bulbs
Old Sep 26, 2022 | 10:09 AM
robo's Avatar
robo
Paul
Thanks Paul, I got it resolved.
Tipat
GX - 1st Gen (2003-2009)
Mar 10, 2017 05:11 PM
boxcarfan
GS - 1st Gen (1993-1997)
19
Aug 23, 2011 08:44 PM
Globalinx
Mar 7, 2011 01:32 PM
SLVRGS3
Oct 12, 2010 06:14 AM
mikemar
RX - 1st Gen (1999-2003)
Sep 18, 2006 04:48 AM
