Crank no start
Old Aug 25, 2022 | 07:42 PM
That2zedbo's Avatar
That2zedbo
10th Gear
Default Crank no start
I have a 2002 lexus gs300 I replaced all plugs and wires due to misfire in cylinders 1 2 and 3 along with a coolant temp sensor. I went to start it and it just cranks but before I changed them it wouldn't even crank. It's my only car as of now please help
Old Mar 1, 2023 | 02:38 PM
arentz07's Avatar
arentz07
This should be in the 2GS models subforum. Moving.
Old Mar 1, 2023 | 03:09 PM
Raven01750's Avatar
Raven01750
Goodness I hate to hear stories like this. When you pulled the plugs, what did you see? You say you changed the "Wires". Are you talking about the coil packs? You really didn't need to spend the money without some pretty simple troubleshooting steps first. Maybe you did though. Did you swap the failed coil packs to the cylinders that weren't exhibiting misfires before you replaced them? When was the car last running? When did it start failing and what DTC (digital trouble codes) did you get when you scanned it? I can tell you with pretty good certainty that the odds of all three cylinders misfiring at the same time are just about nil. As in not possible unless one of a very few things happen. But since you are in New York, I would ask if you are in an area known for RATS. The next question I would ask would be did you notice any loss of coolant lately? Lastly, what other maintenance have you done lately before or after this problem reared it's ugly head. Since this thread hasn't been updated since August of 2022, are you even still monitoring the forum?
Paul
That2zedbo
Aug 29, 2022 12:56 PM
Ronniieron
Feb 6, 2016 10:46 AM
gotenz9064
GS - 1st Gen (1993-1997)
Dec 3, 2012 11:49 AM
gmcaleb
Mar 17, 2011 10:11 PM
teflonvest
Feb 18, 2007 12:07 PM
