Stalling Issue When Decelerating
Old Jun 4, 2022 | 07:47 AM
naluloa's Avatar
naluloa
Question Stalling Issue When Decelerating
Hey guys,
So recently I installed a new head unit and two amps in my GS 400. During the installation I also figured, why not clean my cold air intake (loosened hose clamp, removed filter and cleaned it, re-installed). Excitedly, I went for a drive. Within 10 minutes, as I was coming to a stop, my car stalled. This happened again about 5 more times before I decided to head back home. After a couple days of troubleshooting between my battery (bought a new one as the old one was from 8/2017) and disconnected the power wire from my amps. To this day, my car will stall about one time during my commute to and from work. I've noticed that my once I take my foot off the gas pedal, if I'm near 30 mph, the RPMs will just free fall and it's a hit or miss as to whether or not it will keep going until stall, or until it bounces off ~400 RPM and idles properly. This happens similarly if I'm coasting to a stop or if I start braking. I'm really confused as to what the issue is. Tomorrow I plan on going to Autozone before work to get a scan for some check engine light codes.
My guesses so far are: failing brake booster (shoot me), a vacuum leak somewhere, an idle control valve misbehaving, not waiting long enough after my car was disconnected from the battery for the ECU to properly set fuel-air ratio, or engine misfire. I'd like to note that what's really sounding alarms in my head is the fact that I took off the cold air intake filter, which I believe is the cause of all of this, in addition to maybe resetting my ECU and not letting my car idle for about 10 minutes. I'll post the trouble codes here before I go into work.
Thanks!
Old Jun 4, 2022 | 10:22 AM
DMPesso's Avatar
DMPesso
I’m pretty sure your brake booster has nothing to do with your car stalling. You would feel the pedal mush to the floor from what I remember and make funny noises
Old Jun 9, 2022 | 12:45 AM
naluloa's Avatar
naluloa
Just wanted to say what I did to resolve this issue. So last night I ran my car in my garage and tried listening for any hissing as most recommendations to me were hinting at vacuum leaks. Obviously the cold air intake filter was hissing, but it was pretty loud and so I took it off, inspected it by putting my phone inside of it with the flashlight on. I rotated the filter and noticed that half of one side let a ton of light through whereas the other half didn't. I thought that was weird and seeing as how the issue started only after I cleaned the filter and installed my sound system, and ruling out the sound system, I decided to buy a new air filter. Bought the filter, installed it extra tight, let the car idle after resetting the ECU (it ran very rough for a few minutes while in idle), and I drove it around today on the freeway, highway, drive thru McDonald's, etc. and I think it's safe to say that she's running just like before. Case.
LS400Eddo
65
May 8, 2021 08:50 PM
alberts636
IS - 1st Gen (2001-2005)
Apr 14, 2020 09:27 PM
myLEXsc400
Apr 19, 2016 07:29 AM
dubstar
Jun 12, 2006 10:44 PM
jmooremtb
Sep 17, 2005 11:44 PM
