No crank no start
Old Oct 10, 2021 | 04:16 PM
BryanH19's Avatar
BryanH19
Default No crank no start
So I decided to change my spark plugs and wires while doing valve covers. After I put everything back together I went to go start the car and everything lights up (radio,climate control,steering wheel moves) but when I turn the key nothing happens. I went back and double checked every connectors I took off and they are all back on. Checked the ignition connectors, triples check I had the wires in correct order. Anyone have any ideas I haven’t checked? When I look at my battery voltage it’s around 12.3/12.4. Also after about 10/20 seconds after turning the key my cel light turns off but every other light stays on.
Old Oct 11, 2021 | 04:47 AM
BHustle84's Avatar
BHustle84
Bro did you change the coil packs?
Old Oct 11, 2021 | 07:03 AM
BryanH19's Avatar
BryanH19
No, I didn’t replace the ignition coils, or the little blue connector on each coil
Elingenier
Aug 22, 2019 07:48 AM
Evanner
IS - 1st Gen (2001-2005)
Aug 28, 2017 12:25 PM
Ronniieron
Feb 6, 2016 10:46 AM
jetskiwill
Dec 2, 2013 11:55 AM
Xterminate
14
Sep 23, 2007 02:10 PM
