Fuel pump assembly!!! Help!!
Old Aug 22, 2021 | 04:51 PM
Jackson666's Avatar
Jackson666
Default Fuel pump assembly!!! Help!!
I have a 1999 Lexus gs400
Can I use a Lexus gs300 fuel pump assembly unit or is there other Lexus pump units there will fit, I need the entire unit I believe mine is busted
Old Aug 22, 2021 | 10:40 PM
dwoods801's Avatar
dwoods801
There are plenty of options on eBay, that are for a gs300. Used and new, I would guess the hanger is identical in the 3 big Lexus from this generation. LS/GS/SC, when mine needed replaced, I was able to get a Bosch pump from only $25 and it swapped in place perfectly where the original was. U could probably grab a complete assembly for minimal cost from a pull it yourself style wrecking yard.
How come it’s becoming suspect in your eyes?
Old Aug 30, 2021 | 11:07 AM
lastguy's Avatar
lastguy
Post
would you mind to give link and model#? I have 05 GS300.
Old Aug 31, 2021 | 12:50 AM
dwoods801's Avatar
dwoods801
“would you mind to give link and model#? I have 05 GS300.“
This is a snapshot I pulled in case the link dies and someone wants to find one in The future.
And then here is a hyperlink
https://www.ebay.com/itm/Bosch-Fuel-...-127632-2357-0
Old Aug 31, 2021 | 01:14 AM
dwoods801's Avatar
dwoods801
I don’t know if my ‘99 GS400 uses the exact same pump as your ‘05 GS300, when I punched in the specifics for your car, this was the least expensive Bosch that came up. So…. It’s been 3 years since I did this job and haven’t had any issues with it. So even though it was inexpensive, it does the job asked of it.
https://www.ebay.com/itm/1993-2005-L...-127632-2357-0
YODAONE
Apr 17, 2021 03:41 AM
olsoncam
Jul 30, 2020 05:07 PM
Srpis300
IS - 1st Gen (2001-2005)
May 23, 2018 05:59 PM
n0lasaints
Performance
Jun 30, 2014 12:03 PM
Bankswood
Jan 31, 2013 08:27 PM
