Issue HELP
I have a Lexus 1998 every time I press the brake it beeps for 1 second as if it’s a warning . The beep comes from the inside this only happens when I come to a stop applying my brakes . Anyone knows what may be the problem ?
Is it a beep, like an electronic noise playing from underneath the dash? I believe that would be a 1st? But I have heard several owners complain about their ABS accumulator making a buzzing noise when they are stopping and holding the brake pedal. Search the tags “ABS” and “Buzzing”. You should be able to find multiple threads covering the problem and solution.
Check to see if the brake fluid is low. You may be just hitting the low fluid mark when applying the brakes. This lets you know it may be time for some replacement brake parts. Or possibly a leak that needs addressed.
BayAreaLex
Sep 12, 2012 07:16 PM
