Loose wire... Help!
Old Dec 30, 2020 | 10:03 AM
Lex4002020's Avatar
Lex4002020
Default Loose wire... Help!
I have a 2000 GS400. A few months back I changed the timing belt,water pump etc. (with the help of this forum. Many thanks to those of you that posted tutorials on that process.) Everything has been running good no issues. Today while doing an oil change I noticed this wire hanging. I’m assuming it’s a ground wire but I don’t know where it’s supposed to be connected. Can someone please point me in the right direction as to where it bolts up.
Old Dec 30, 2020 | 11:41 AM
bbmach's Avatar
bbmach
It almost looks like it belongs near the alternator. Follow the natural curve of the wiring harness and see where it leads you...
Old Dec 30, 2020 | 01:10 PM
XLIX's Avatar
XLIX
Looks like that bracket bolts to the alternator. I believe that wire is your battery negative ground cable. You'll want to make sure that's fixed. Most likely the bolt that secures the bracket is missing, so you'll want to source the correct one.
Old Dec 31, 2020 | 04:28 AM
TrueGS300's Avatar
TrueGS300
Thats a ground. It connects to the block behind the alternator and in front of the engine mount. Should see a hole missing a bolt.
chrshea
Hybrid Technology
Feb 12, 2022 11:31 PM
pdoyle
Dec 4, 2020 03:38 PM
Shannbebe
Nov 27, 2020 06:03 AM
DropD
GX - 2nd Gen (2010-2023)
20
Sep 14, 2019 12:49 PM
mick5410
Apr 12, 2012 07:53 AM
