Door locks not working
Old Jul 5, 2020 | 04:48 PM
Hobbes12's Avatar
Hobbes12
Default Door locks not working
Hi everyone. I’m new to this forum thing. I have a 1999 GS 300 and the locks are not working. Can all the actuators go bad at once and is there a way to test which one is bad or any ideas on how to fix? Thanks!
Old Jul 5, 2020 | 05:22 PM
gs30's Avatar
gs30
Look up door actuators on the 2gs forums, this problem has been talked through quite a bit
Old Jul 6, 2020 | 07:32 AM
Mike246's Avatar
Mike246
It is most unlikely that all of the actuators have failed. I suspect that maybe the battery in your remote needs replacing. Have you tried operating the ignition key in the driver's door lock which should secure all doors? This will give a clue to what's wrong.
Old Jul 6, 2020 | 06:03 PM
Hobbes12's Avatar
Hobbes12
With the remote you can hear it try to lock but will not. If you use the key in the door sometimes it will lock one or two or all or none but the one with the key. Same when you try to unlock with the key. Is there a way to check which one or is it best to just replace all? I have tried the sit in the car and manually unlock all doors and try to lock with the lock button, nothing same when trying the unlock. Thanks for all the input!
Old Jul 6, 2020 | 09:29 PM
Mike246's Avatar
Mike246
Understood. First thing is to check your car battery voltage with the engine off. If it is 11.5 +, that's fine. If it is under 10 then this is the likely culprit.
This advice does come from experiencing the same issue!
Old Jul 6, 2020 | 10:42 PM
Tuanville's Avatar
Tuanville
Does your car start up fine? Yes? Then lock the door with the door switch. Do they lock? No? Then those are the one with the bad actuator. If one of your door lock actuator are bad, they will click twice. Ez.
Old Jul 7, 2020 | 11:57 PM
KTGS300's Avatar
KTGS300
Unlikely, but it does happen. All of mine failed at the same time.. well, within a few days of each other.
Shnerez420
Jun 24, 2019 08:57 PM
pmusser67
Apr 30, 2019 08:23 AM
gonzalezsg
Jul 17, 2018 05:17 PM
canes580
Jun 20, 2016 12:40 PM
AKA K2
RX - 1st Gen (1999-2003)
Mar 3, 2008 02:51 PM
