Tap Handle Shift Knobs
Old May 19, 2020 | 05:44 PM
cantbevanc's Avatar
cantbevanc
Default Tap Handle Shift *****
So, I have a gnarly tap handle and am having a helluva time finding a threaded insert to downsize the threads to fit my GS430 ****. Every fitting/insert I have found is just 2-4mm off.
The Tap Handle is 3/8"-16 and the shifter shaft is m8x1.25. Any leads or links would be much appreciated.
Old May 19, 2020 | 06:18 PM
firelizard's Avatar
firelizard
This may not be the help you're looking for, but if I were in your position, I'd just fill the tap handle with epoxy and drill/tap that. Of course, this assumes you have a tap set on hand.
Old May 19, 2020 | 06:57 PM
cantbevanc's Avatar
cantbevanc
I've considered more diy options like that but I'm confident theres a threaded insert to fit the shift thread, I've found numerous designs for the aforementioned but none in the correct size, yet that is but it would be a resort if nothing else! Thanks man!
1UnaZ
Aug 8, 2018 06:30 AM
CharmCtyIS
RX - 4th Gen (2016-2022)
Jan 18, 2018 06:54 AM
13IS250C
Dec 4, 2013 01:54 PM
sxylxy
Feb 26, 2007 10:35 AM
