Car won't start
Old Jan 28, 2020 | 12:12 PM
Corey513's Avatar
Corey513
Default Car won't start
So i have a Gs300 2001 i recently had a flat tire so my car sat for couple days but now it won't start. It cranks but it just won't turn over. This problem just started today and I'm not sure why
Old Jan 29, 2020 | 07:51 AM
kevin3344's Avatar
kevin3344
How many miles? Were there any symptoms of problems prior to this? Start with checking your spark and fuel see below.
Old Jan 29, 2020 | 10:56 AM
Corey513's Avatar
Corey513
Over 200,000 miles i never had this problem before its the first time
Old Jan 29, 2020 | 11:51 AM
kevin3344's Avatar
kevin3344
Have you ever had the fuel pump replaced? I'm wondering if it's starting to go out. Turn the key to the "on" position and have someone stand near the driver rear door and see if they hear the pump "prime". There should be a light buzzing sound. You can also grab some starting fluid and spray it in the intake and see if it runs for a bit. That's how I diagnosed a bad fuel pump on our IS250.
Old Feb 14, 2020 | 03:47 AM
dwarren's Avatar
dwarren
Just started having the same problem with just about the same mileage. Mechanic plugged in his obd ll scanner and got a P0193 code. With the scanner plugged in it starts. He has no idea why. Researching it seems to point to fuel pressure sensor. He recommended taking it to the dealer since he didn’t know. We’re in flux right now!!
Old Feb 14, 2020 | 05:04 AM
kevin3344's Avatar
kevin3344
Disregard that last comment I thought this was the 2IS forum lol. Have you tried starting fluid?
Old Feb 14, 2020 | 06:14 AM
kevin3344's Avatar
kevin3344
dwarren are you talking about a 2IS or 2GS? Just want to make sure you're in the right forum. If you have a 2IS, there is a FPS recall that Lexus can check for you through the TIS system. Give them a call if you haven't had the recall done.
https://static.nhtsa.gov/odi/rcl/201...4V647-0774.pdf
Old Feb 15, 2020 | 03:34 AM
dwarren's Avatar
dwarren
Thank you I’ll check on that
jrandallc
Sep 6, 2019 03:30 PM
winner155
24
Feb 15, 2012 05:13 PM
JNew
Nov 20, 2007 08:06 AM
