Supra brakes conversion (info needed)
Old Aug 11, 2019 | 03:44 PM
Bongolouie's Avatar
Bongolouie
Default Supra brakes conversion (info needed)
Someone told me that the brake rotors & calipers from Toyota Supra’s fit on Gs 300/400. Is that true? Can someone post a diy on making that swap please?
Old Aug 11, 2019 | 06:39 PM
firelizard's Avatar
firelizard
You literally just bolt them on.
http://planetsoarer.com/suprabrakesI...akeUpgrade.htm
Old Aug 11, 2019 | 06:41 PM
Bongolouie's Avatar
Bongolouie
Σ('◉⌓◉’) whoa that just blows my mind, for me at least this is awesome!!! Thanks bro
Old Aug 11, 2019 | 06:43 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Just be aware your stock wheels are likely not to fit over them unless you use a spacer.
tons of threads in this if you search, probably some links in the faq
Old Aug 11, 2019 | 06:44 PM
Bongolouie's Avatar
Bongolouie
Ok thanks for the tip
Old Aug 12, 2019 | 05:49 AM
TrueGS300's Avatar
TrueGS300
I heard LS400 brakes are as good and usually much cheaper without the "Supra tax". Might look into them and what's involved in fitting them.
Old Aug 12, 2019 | 11:18 AM
captainva's Avatar
captainva
LS400 require a minimum of a 17mm RCA or you'll hit the tie rod. Also the supra and LS400 calipers only bolt up to the front. Rear pattern is different
Old Aug 13, 2019 | 03:46 AM
brainsurge's Avatar
brainsurge
LS460 fits with custom brackets from suprastore, with is-f discs
Feijai85
Jun 7, 2012 09:20 AM
moses
Suspension and Brakes
Oct 13, 2004 11:55 PM
RAV
Wheels, Tires & Brakes Forum
Mar 25, 2004 06:00 PM
texis_300
Jul 5, 2001 08:48 AM
GlobeCLK
30
Jun 27, 2001 02:21 PM
