Gs300 A/C
Old Jun 18, 2019 | 04:21 PM
Luis1993's Avatar
Luis1993
Default Gs300 A/C
So here’s the deal When I first bought the car ac was working fine cold af PO had wired in a switch running to the dash that would turn the A/C compresser on not even a couple days later on of the wires came loose I tried putting back and nothing no power has almost been 3 years with out ac smh I have no idea wtf to do and PO being a ***** and won’t help me I been the 3 different shops and there as useless as The PO anyone have any ideas ?
Old Jun 18, 2019 | 05:28 PM
sbagdon's Avatar
sbagdon
For one, I'd say fix the underlying problem. That appears to be a radiator fan, so guessing the compressor engages, yet the fan doesn't, killing cooling efficiency? A bad fan relay?
Do you have good pressure when the compressor engages, and did you get he codes from the a/c cluster?
Old Jun 18, 2019 | 05:31 PM
Luis1993's Avatar
Luis1993
When I turn it on from the controls the fans from the engine turn on Its just not blowing any air. Switch in dash does nothing not Turning on the blower.
Old Jun 18, 2019 | 08:28 PM
sbagdon's Avatar
sbagdon
Pull the codes from the climate cluster, find out what the cluster thinks is wrong with the system.
I'm sure that what you're experiencing has happened before. Yet first we need what the car says is wrong with itself.
Old Jun 19, 2019 | 07:00 AM
TrueGS300's Avatar
TrueGS300
Check your fuses. Probability blew one from the ghetto wiring.
Old Jun 19, 2019 | 11:57 AM
Luis1993's Avatar
Luis1993
That’s what I was thinking lml g looks tho😂
Old Jun 20, 2019 | 08:49 AM
Luis1993's Avatar
Luis1993
Checked heater fuse in drivers side kick panel looks good also check engine fuse box compressor relay and other relays seems to be alright don’t know wtf to do now 🤦*♂️
Old Jun 20, 2019 | 10:22 AM
SaiyanGS3's Avatar
SaiyanGS3
WTH is ghetto wiring!? There are only two options; good or bad wiring? How to you classify ghetto wiring? Is there such a thing as classy wiring, affluent wiring, or middle class wiring? This side of Club Lexus is trash now...exactly why I stay on the LS side nowadays.
Old Jun 20, 2019 | 05:44 PM
TrueGS300's Avatar
TrueGS300
Obviously you don't stay in the LS section. Do you all meet for wine tasting in your super classy LS Lexus'? The "PC" police is here. Everyone watch out .
2ks
RX - 1st Gen (1999-2003)
Jun 11, 2021 01:23 AM
zwii
Mar 30, 2020 10:05 PM
avalon42
Aug 14, 2012 02:48 AM
gdoutlex
North Texas Lexus Club
Aug 24, 2010 12:01 AM
KCLEX
Feb 9, 2009 04:40 PM
