Throttle
Old May 23, 2019 | 09:21 AM
Lena's Avatar
Lena
Default Throttle
I'm having problems with rpms going really high even in park... When I press on gas pedal doesn't gain speed
Old May 23, 2019 | 07:29 PM
TW99GS300's Avatar
TW99GS300
Not enough information. But best guess is there is a vacuum leak and/or the throttle position sensor is incorrectly set.
Question is, even if someone guessed the correct issue, would you know how to fix it?
Take it to a mechanic that knows what they are doing and pay them for their expertise.
Old May 24, 2019 | 03:03 AM
sbagdon's Avatar
sbagdon
Yea, sounds like TPS, yet we don't read minds (cars or humans).,
Any engine codes?
Old May 24, 2019 | 05:38 AM
TrueGS300's Avatar
TrueGS300
It is very likely throttle related. A rodent could have ate through a vacuum line, a tps's wires chewed, or the sensor failed itself. IAC could be acting up. Throttle may be gummed up and out of parameters. They do weird things when no longer reading right. You have to start with a code scan and a visual inspection of the engine hoses and wiring isn't a bad idea if you know what to look for.
oneforu2c
May 16, 2022 10:18 AM
EMCM
Performance
15
Sep 10, 2021 04:31 PM
Jen4081
Oct 1, 2014 12:23 AM
sherwoodjb
Jan 26, 2011 07:43 PM
mayad79
Jan 9, 2009 05:38 PM
