Interchangeable bushing question
Old Apr 25, 2019 | 08:42 PM
TrueGS300's Avatar
TrueGS300
Default Interchangeable bushing question
I searched around and have found several threads on interchangeable parts for 1st gen GS SC and LS models etc. But none for the 2GS and IS300. Right now I am looking into replacing my front lower trailing arm bushings with a poly set. But just like when I went to locate my headers I had better luck searching for the IS300. Im 99% sure the trailing arm bushings (aka caster arm bushings) are the same as well as the whole arm. But like I've found before, there is so much more after market support for the IS300 that it's cheaper to order for the IS300. Anyone know if they are the same?
Old Apr 26, 2019 | 07:24 AM
captainva's Avatar
captainva
FIGS engineering sells superpro poly bushings for the 2GS. Those are the ones to get as they're the best quality and they just work with no BS. The customer service is also excellent!
V8LexGS
May 17, 2013 08:53 PM
Opaque
IS - 1st Gen (2001-2005)
Aug 19, 2011 06:11 AM
madmaxoo7
Aug 2, 2011 08:26 PM
tonysgs300
Suspension and Brakes
Dec 30, 2009 09:10 AM
