GS300 Limp mode?
Old Jan 21, 2019 | 04:50 PM
Markmorbid's Avatar
Markmorbid
Question GS300 Limp mode?
So i replaced my valve cover gaskets on my GS and i checked what needed to be connected.
Started the car and i had a hard time starting it. (oil was in the spark plug wells and I had no way of taking the oil out)
Once I got it to start it idled high... maybe between 1.5k -1.8k
I popped the hood again and noticed some stuff was still unhooked and i put all the stuff back. and I gave it another look to make sure it was all good.
The car makes an electrical noise like something is moving when the accelerator pedal is pressed. sorta like when you press on the brake to switch from Park to Drive.
Everything is stock all I did was replace valve cover gaskets and spark plugs.
Only place that got me some concern was the intake side with most of the vacuum hoses..
Any idea?
I hope I was as good at explaining.
Before all this the car ran great it just needed new valve cover gaskets lol it was brittle af.
Old Jan 21, 2019 | 11:02 PM
TW99GS300's Avatar
TW99GS300
Oil in the plug valley can be removed with a rag and compressed air. Spraying some brake or throttle body cleaner fluid would help.
Electrical sound when the accelerator is pressed, that's the throttle control motor. Electronic Throttle Control System or ETCS-i should be stamped on your throttle body.
Idling high is a good indicator of vacuum leaks. Check all of your connections
Old Jan 22, 2019 | 06:12 PM
Markmorbid's Avatar
Markmorbid
Well im more or less trying to figure out what went wrong with the TB no activating all the way.. all the wires are hooked up. it all worked fine before the valve cover replacement
Old Jan 22, 2019 | 06:27 PM
TW99GS300's Avatar
TW99GS300
Is there any lights on? Check Engine / VSC / VSC off? If so, scan for codes.
Doneve79
Dec 19, 2016 07:39 PM
guku0701
Feb 23, 2012 07:21 PM
koolcat
Sep 22, 2010 02:49 PM
dario
GS - 1st Gen (1993-1997)
Jun 30, 2009 11:01 AM
jstyles129
Sep 1, 2006 10:17 PM
