Broken front lower control arm
Old Jan 5, 2019 | 07:49 PM
WannaBoost's Avatar
WannaBoost
Default Broken front lower control arm
Hello,
I hit a pothole driving tonight, a bad one, and the lower control arm snapped. Everything else looks fine. I ordered the part, will be here on Monday. This is my first time doing a lower control arm on this car. Just wanted to know if anybody had any pointers or info on replacing it. It looks pretty straight forward, just a few bolts and that’s it. Do I need any special tools to get the arm out of the lower ball joint or will it come of after I loosen the bolt? Thanks for any info!
Old Jan 5, 2019 | 07:59 PM
lexo98's Avatar
lexo98
https://m.youtube.com/watch?v=Twt47cvQFjY
but if your asking if the balljoint will fall right out after being unbolted it will not. I’d rent a tool or buy one for it. There are other ways but good luck trying them if your not experienced
Old Jan 5, 2019 | 08:19 PM
monkey92's Avatar
monkey92
you can rent a ball joint separator for free at the auto stores. It makes the job easier. good luck
Old Jan 5, 2019 | 08:23 PM
firelizard's Avatar
firelizard
Replace the lower ball joint at the same time. Heck, replace the tie rod end and upper too, while you're in there. If you're not reusing a balljoint you can just hammer it out, doesn't matter if you ruin the threads because it's going in the trash. Pickle fork is helpful too (also only if you're throwing the part in the trash after). Ball joint separators make it a lot easier though.
Old Jan 5, 2019 | 09:51 PM
WannaBoost's Avatar
WannaBoost
I’m reusing the ball joint. I’m waiting around to find another gs in better condition and black interior, this car has just too much wrong with it and the complete wrong interior color for me, so I want to replace as little as possible. This car will end up giving me the engine that I plan to tear down and build, as well as spare parts/bolts as needed. I didn’t know I needed a ball joint separater to get the lower control arm to disconnect from the ball joint, so I appreciate that. I’m pretty good working on engines, but haven’t really done work on suspension parts before, so I’m kind of a newb at this, but I need the experience as when I get the new gs I will be slowly replacing everything with New or performance parts and bushings. Is there anything else I should be mindful of? Btw I guess I should have mentioned this is for the lower control arm #1, the straight one not the #2 which is curved.
Old Jan 5, 2019 | 11:51 PM
salimshah's Avatar
salimshah
25 Year Member
I am doing a premptive replacement ... directional control was sloppy at higher speed . Just make sure you get the newer control arms (TRD type). I will be heading to an alignment shop afterwords. Only advice would be dont piecemeal the suspension, get all of it done once and then pay once for alignment.
Salim
PS ... Just noticed we are talking about different parts.
Alexusc300
Jun 6, 2015 03:09 PM
CManolo
Dec 5, 2014 03:35 PM
e-man
Suspension and Brakes
16
Jun 21, 2009 09:21 AM
92blacktt
May 17, 2009 05:32 PM
questnyc
May 17, 2008 09:49 PM
