Shifting issues
Old Oct 25, 2018 | 02:37 PM
Gudder's Avatar
Gudder
Default Shifting issues
Hey guys new to the lexus. Just bought a gs300 liking so far. Big question though. When I come to a complete stop and take off the car hesitate 10 to 30 sec before taking off. Or when I’m just cruising and try to pass someone it hesitate or very laggie. Feels like the trans is binding up. What’s could this be?
Old Oct 25, 2018 | 02:51 PM
mate01's Avatar
mate01
Replace or clean the maf sensor.
Old Oct 25, 2018 | 04:18 PM
Gudder's Avatar
Gudder
Is that the one in the air intake correct? Do they normally through codes of it was bad or clogged?
Old Oct 25, 2018 | 04:38 PM
mate01's Avatar
mate01
Correct. It doesn't always throw a code. Replace air filter too.
Old Oct 25, 2018 | 07:49 PM
Gudder's Avatar
Gudder
Got ya. I was thinking on changing the intake to cai. I’ve read it’s no point. Some say can tell a little change. More in sound. Worth changing to cai or just do a k&n drop replacement filter? Thanks for the advice!!!
Old Oct 25, 2018 | 08:17 PM
mate01's Avatar
mate01
Just do the k&n. We call those other ones hot air intakes. lol
Old Oct 26, 2018 | 12:09 AM
TW99GS300's Avatar
TW99GS300
It's also possible that you have a crack/leak on that tube with the folds. There's a resonator box just above the header and it will collect oil over time from the exhaust side valve cover, eventually heat/oil/time will break it down. If you rev the motor do you see the fold accordion up? If not then you'll want to replace it.
Old Oct 26, 2018 | 02:11 PM
Gudder's Avatar
Gudder
Not sure I will have to check it. So right above the header there’s a box that will fold while rev it?
Old Oct 31, 2018 | 12:46 AM
TW99GS300's Avatar
TW99GS300
the tube with accordion will fold when rev, the box is on the bottom side of the tube and has a tendency to crack
Old Oct 31, 2018 | 09:46 AM
Gudder's Avatar
Gudder
I might be over looking. But do u have a diagram of this?? I did find a few vacuum leaks. And it finally through a code for misfire # 2. Going to do the tune up tonight and see what happens.
Old Oct 31, 2018 | 04:21 PM
Gudder's Avatar
Gudder
Ok I see what your talking about now. So did a tune up. Changed a few vaccum lines. Cleaned the Maf. Idle runs perfect slightly rev it up does fine. Give it half or full throttle falls on its face and seems to choke out. No cel lost on what it could be
Old Nov 1, 2018 | 05:50 PM
BiGEZ's Avatar
BiGEZ
Reset your ECU. Disconnect the battery negative cable for a few minutes and reconnect. Also, check again for vacuum leaks.
Old Nov 3, 2018 | 10:28 AM
Gudder's Avatar
Gudder
What’s the best way to test vaccum if I don’t have a smoke machine? Also started to drive it again after doing the tune up and cleaning map. It does have better power. And the hesitation has cleared up a lot. To even gone. But there is still a little miss to hesitation when getting on it hard. Very hard to notice. Still puzzled really trying not taking it to the dealer. Lol. I also noticed when doing the tune up the first coil pack where the main harness plugs into, the clip is broken. I zip tied to just make sure it does not pop off. Do they have replacement for the black clip? Or u have to install a new harness??
Old Nov 4, 2018 | 07:08 PM
TW99GS300's Avatar
TW99GS300
google gs300 Coil pack harness
Old Nov 8, 2018 | 07:56 AM
Gudder's Avatar
Gudder
Just google the coil pack connector that’s simple to do. Have to order one and Install.
So I caved in took the car to the dealer. Well I should of listen. Lol but I didn’t want to waste the money of it wasn’t the maf sensor but they said maf sensor or as they called it the air flow meter. They said they could do it $450. So I ordered the part and will be installing it in a couple of days thanks guys for all the info. I’ve been out of the gas world for a few years. Now was hesitated on working on it. Lol getting my confidence back up thaksmagain guys
