Temperature gauge, what is normal?
Old Aug 13, 2018 | 07:03 PM
KTGS300's Avatar
KTGS300
Default Temperature gauge, what is normal?
For all the GS300 owners, where does your temperature gauge needle sit when engine is at normal operating temperature? Just wondering because I was told mine might be a little high and it's sitting just a little past the 2nd tick mark right in the middle.
Old Aug 13, 2018 | 10:40 PM
shwalker07's Avatar
shwalker07
Mine stays right in the middle when warm. If your temp is starting to get high start with checking some of the basic things like checking coolant level and making sure radiator and a/c condenser is free of debris
Old Aug 14, 2018 | 01:39 PM
n1ck's Avatar
n1ck
Mine sits right under the middle mark most of the time. Never really see it go past that, even on really hot days.
Old Aug 15, 2018 | 08:20 AM
kevin3344's Avatar
kevin3344
I think it's the same for GS400....mine is just past the 2nd tick mark as well. It looks a little high but if you look closely the middle mark is actually a bit below the middle (using the gas gauge as reference)
Old Aug 15, 2018 | 09:42 AM
Noosik's Avatar
Noosik
I had two gs300, 1998 and 2001 first 98 one temp was little below middle, and 2001 sits right in middle. I swaped engine from 2001 to 1998 car and now it shows temp in middle. I think it has something to do with temp sensor.
haulin79
32
May 24, 2024 12:31 AM
SC3coupe
GX - 1st Gen (2003-2009)
Nov 11, 2015 02:31 PM
cobalt91
May 22, 2014 07:05 PM
Vtur
Feb 14, 2012 07:48 PM
Jmai22
GS - 1st Gen (1993-1997)
Dec 13, 2002 07:27 PM
