Sporadic HID Auto-Leveling
Old Mar 4, 2018 | 06:59 PM
justim's Avatar
justim
Default Sporadic HID Auto-Leveling
Hey everyone,
My GS300 with HID auto-leveling has recently started to move when it doesn't need to. There are no lights on the dash regarding the auto-leveling system. I assume it's not a servo issue since both headlights move at the same time so I'm guessing its a sensor issue. Do you know any way of diagnosing this? Which parts might I be looking at to replace? Below is a video of the vehicle sitting in a flat driveway in park and the lights randomly adjusting.
Old Mar 4, 2018 | 07:19 PM
MikeFig82's Avatar
MikeFig82
Originally Posted by justim
Hey everyone,
https://www.youtube.com/watch?v=jsVmiYtrnmU
The car has both sensors on the left wheels F/R. They are tied to the suspension arms. Check if maybe the nut that holds the levers to the sensor is not loose.
Old Mar 4, 2018 | 07:54 PM
justim's Avatar
justim
Ok thanks, I'll check those out
Old Mar 5, 2018 | 03:40 PM
99rx's Avatar
99rx
I would start with the sensors on the front wheels. Take the connection off and clean the contacts as well.
Old Sep 29, 2018 | 01:19 PM
justim's Avatar
justim
Update to this old thread
The leveling warning light has been constantly on for the past 3 months but the headlights still do that initial up-down level when the vehicle starts. I'm confident the motors are fine so I'll rule them out.
I just removed the front ride height sensor and checked it on a multi-meter. I don't know what the expected values are but it did change resistance when sweeping from an up and down position. It looks like it is ok.
I replaced my cracked HID housings a few years ago and the new ones came with an HID leveling ECU. I have my old headlight ECU as a spare so Ill try replacing that after testing the rear height sensor.
Old Oct 5, 2018 | 10:19 PM
Arcadian's Avatar
Arcadian
Ok, that's interesting. My car was hit on the front right corner. The fender was replaced and the the inner sheetmetal pulled. But, the light still points a little up and to the right. My lights no longer go through their up-down cycle when starting the car and turning on the lights. But, they do still react to acceleration and seem to be at the right height upon start-up.
Old Feb 2, 2019 | 09:39 PM
kaliehulum's Avatar
kaliehulum
Default Hid
where is the nut at
srinukonat
Mar 5, 2017 04:16 PM
HIDXTRA
Lighting
Aug 28, 2010 06:37 PM
Tyke
Oct 10, 2007 11:44 AM
Devir
Lighting
Sep 10, 2007 09:15 AM
BallinLX
Jan 24, 2003 04:11 AM
