window problem drivers side
Old Feb 25, 2018 | 05:04 PM
beachit321's Avatar
beachit321
Default window problem drivers side
drivers side window will not go up anymore. Press button to go up and hear double click sound from behind door, guessing click comes from motor, but window does not move at all. All lights work on switch and all other windows working. Has to be something simple?? Any ideas
Old Feb 25, 2018 | 07:56 PM
silverbul's Avatar
silverbul
Either 2 things. Window regulator or module. But it sounds like the regulator
Old Feb 25, 2018 | 08:30 PM
beachit321's Avatar
beachit321
the regulator is the metal track gear that the window sets on? it made no funny noises when it sometimes worked. it would go up then down on its own when only hitting the up button, but would eventually go all the way up. now it just clicks like it is getting power but not sending it properly? the other thread gs300 window one has some more details in it.
Old Feb 28, 2018 | 06:05 AM
silverbul's Avatar
silverbul
Sounds like the regulator is bad. Try spraying the window tracks with WD40. Dried window tracks will make it hard to go up & down too. Just know in the future if you hit the button and hear nothing it's the module.
Old Feb 28, 2018 | 06:54 PM
TW99GS300's Avatar
TW99GS300
Can be the relay in the door ecu. Check window operation by applying 12v directly to the motor first. If that operates fine then it's the relay in the ECU. If that doesn't work then replace the motor.
Ham
Dec 20, 2018 09:15 PM
Eddycanuck
Feb 19, 2013 11:59 PM
khmer470
GX - 1st Gen (2003-2009)
Aug 25, 2011 08:14 PM
JiBBeL
RX - 1st Gen (1999-2003)
Sep 8, 2010 11:12 AM
white93
Maintenance
May 9, 2003 03:59 PM
