What now
Old Jan 7, 2018 | 07:57 AM
TW99GS300's Avatar
TW99GS300
Sounds like he's hoping for blown HG so he has a reason to swap...
Old Jan 7, 2018 | 08:28 AM
BayAreaLex's Avatar
BayAreaLex
Thread fail...
Old Jan 10, 2018 | 12:51 PM
100bajan's Avatar
100bajan
Originally Posted by Mr Jokster
OMG, why so vague! Post what the problem was!
What is vague??? I posted exactly what I know!! I was never told what the "problem" was so how do you expect me to say what it was? I'm sure I mentioned that I don't know about cars, so I could only go off of what I was told!
Old Jan 10, 2018 | 02:37 PM
SaiyanGS3's Avatar
SaiyanGS3
I'm about to take my hiatus again. I can't take these thread anymore.
Old Jan 10, 2018 | 06:38 PM
silverbul's Avatar
silverbul
Your never had a problem to begin with. Now what happens when you put water in a pot on the stove and you let it boil? It gets hot and evaporates. Same problem you had. Instead of you pouring coolant in your system you adding water daily as you state. All it was doing was getting hot and evaporating causing your temp gauge to go high and you overheating. Drain everything out, put the proper mixture that's needed then burp the system to release air bubbles and enjoy your car.
Old Jan 11, 2018 | 08:05 AM
100bajan's Avatar
100bajan
Thumbs up
Exactly. This is something I didn't know. Apart from the cracked radiator ( I did see the crack), and the switch (because the fan wasn't turning on)
Old Jan 11, 2018 | 09:00 AM
silverbul's Avatar
silverbul
Only water that you need to add is distilled water. Regular tap water has lead in it and causes rust. The overheating problem cracked your radiator. That evaporated water pressure build up had to escape somewhere. Either a hose or radiator had to go.
Old Jan 11, 2018 | 09:05 AM
Htony's Avatar
Htony
Originally Posted by 100bajan
I know nothing about cars or how to tell if it really is blown. There is no smoke coming from the exhaust, no shaking, no nothing. What are some tell signs of a blown head gasket?
Do a dye test to detect exhaust gas in the coolant.
Old Jan 11, 2018 | 10:16 AM
Letsride's Avatar
Letsride
Issue resolved....(whatever it was). This is now closed!
DanES300
14
Feb 9, 2013 04:40 PM
gs2impress
GS - 1st Gen (1993-1997)
28
May 24, 2011 10:07 AM
gsCrazy
Apr 16, 2010 10:39 PM
ken8817
Jun 29, 2006 08:24 PM
scoarer
Jan 20, 2006 03:15 PM
