Aristo Swap Does Not What To Run
#32
I really want your build to work, but I don't think your MAF is "bad" but rather not wired up right, or something else that feeds critical info to the ECU in order to start like Coolant Temp, Cam/Crank Sensors, TPS, etc.
Your car sounds exactly like many situations I've experienced where the electrical circuit is not complete
#33
#36
Awesome I bet she runs great too! Its my pleasure and good job man. Here is a link that shows what wires to move on the ECU pins from the igniter plug to get your tach working.
https://www.clublexus.com/forums/gs-...-begins-2.html
#43
#44
A MIL is a check engine light code.
So you got it to start once, when you messed with the wiring, so I'm still sticking to the fact that something is shorting or not completing circuit.
Triple check your wiring. Check out the fuel pump ECU and wiring in the back of the car/trunk.
Also, maybe check out this video, I don't know if it will help much but it has some key things shown with the ecu.
He starts a 2JZGTE in his garage hooked up to nothing but a battery, and a bucket with fuel in it.
#45
https://www.youtube.com/watch?v=wf-u7a99anY
But it does look like I have Low Spark Im thinking of buying a HKS Twin Power Ignition Box maybe thats what I need in order for my car to Start Up....
Thanks Gs400
