Help with GS300 aristo swap
I have a black 2002 GS300 and I want to do the aristo 2JZ-GTE motor. I would also like to do a manual conversion. I need help on the process about doing these things.
Thanks
Thanks
Judging by your 1 post count, I'm going to assume you literally did no research whatsoever. There is a search bar, top right of your screen. USE IT, it's amazing the things you'll find.
WieseGS300,
First, Welcome to the forum,
Second, Look on the DIY Thread and you can found a lot of Info about this topic. Engine, Trans., Dif., Ect.
https://www.clublexus.com/forums/gs-...iy-thread.html
Good Luck with your project
I didnt have to do anything to mine to get clearance, however, you do have to customize the pipe a little to make it connect. I cut mine.
Btw, did you do auto or manual trans?
