gs 300 question
can anyone explain in layman's terms what the "calibration" feature is useful for in the navigation system.
you can calibrate "distance" and "position". I have no clue what this means or when/if I should be calibrating.
thanks in advance.
scrim67
thanks in advance.
scrim67
calibrating would be used when your nav is showing inaccurate positions. if you're at an intersection and it consistently shows that you're a good distance off...its time to calibrate. actually doing it isn't hard either
