Rear View Camera
Old Jul 30, 2015 | 06:38 AM
PandaGS300's Avatar
PandaGS300
Default Rear View Camera
Hey everyone,
So i bought a Pioneer double din, with backup camera capability.
Bought one of the popular backup cameras off ebay that guys use here.
Now i need to know what wires are for reverse to activate the headunit.
Also, do i need to run a sepearate power wire for the backup camera or can i just feed off the factory reverse wire.
Its a little confusing but just needed some clarity.
Any help will be much appreciated.
Thanks
Old Jul 31, 2015 | 05:46 PM
jorhelj's Avatar
jorhelj
just ground the negative wire from the Camera to metal inside the trunk on the passenger side and while you are there unplug the Back up light bulb from your tail lights use a voltmeter and find the positive wire tap into it and wire the positive power wire from the camera and run 1 power wire to the back of the Head Unit it should be labeled rear or back up and that's it as soon as you throw your car into revers the back up lights light up and activate the back up camera.
Old Jul 31, 2015 | 09:57 PM
SenecaRex's Avatar
SenecaRex
Exactly how i've done it in the past ^^^
Old Aug 3, 2015 | 12:10 PM
PandaGS300's Avatar
PandaGS300
Thats not too much power being drawn from the Reverse wire?
Old Aug 3, 2015 | 02:21 PM
jorhelj's Avatar
jorhelj
No it's fine
Old Aug 3, 2015 | 10:05 PM
Fromthesha's Avatar
Fromthesha
Is the wire in a different pin or a different color in different cars? Just wondering why noone just says what color wire in what pin it is. Just to save everyone from breaking out the multimeter. Panda, let us know which wire and I will check my harness, i just bought a backup camera after reading your post
Old Aug 5, 2015 | 12:13 PM
Foob's Avatar
Foob
Sub'd to this thread
Old Aug 5, 2015 | 12:31 PM
Debonair's Avatar
Debonair
I doubt anyone who did this install took note of the wire colors and kept them handy in preparation for other members who do not want to use their own multimeter or test light. Everyone so far is suggesting the quick and easy solution they used.
If possible, you should report back with the wire colors, or even better put together a DIY on it. A reverse camera install is definitely missing from the 2GS DIY thread and would be a great addition.
Old Aug 5, 2015 | 07:43 PM
Fromthesha's Avatar
Fromthesha
Lol I guess you're right, and not to take anything away from their advice, I'm just surprised that, will all the info on this forum, nobody has diagramed it. I will report back when I get a chance.
Old Aug 5, 2015 | 10:50 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
what type of Pioneer model did you go with?
Old Jul 7, 2016 | 03:25 PM
Agent$mith's Avatar
Agent$mith
Bumped an old post. The power wire is red/blue and the ground is white/black. I just did my rear camera.
Old Jul 13, 2016 | 10:23 PM
Foob's Avatar
Foob
Thanks AgentSmith!
Old Sep 3, 2016 | 02:27 PM
Foob's Avatar
Foob
Default Hooked up my camera. One problemo
How do I get the camera to automatically turn on on my dash? I've got a kenwood 372bluetooth model with camera interuptions on. I have to manually put the headunit to r camera, then throw the car into reverse for the screen to show the camera. And the camera doesn't get power without me going into reverse. What gives? Followed all the directions from agent smith.
Old Sep 3, 2016 | 11:29 PM
istundra's Avatar
istundra
get your 12V+ power from the switched ACC like cigarette lighter.
You are getting the 12V+ from your reverse wire, that's why no power until you go to Reverse
Old Sep 4, 2016 | 10:47 AM
Foob's Avatar
Foob
So the only way i could get it to work correctly is to run a power wire from the trunk all the way to the front cig lighter?
