Accessory Connection
Old Mar 21, 2015 | 02:33 PM
Mike246's Avatar
Mike246
Default Accessory Connection
Hi all.
I have a 1998 GS300 and am installing a VHF Ham Radio transceiver which takes around 6 amps when transmitting.
This is too high a current for the cigarette/accessory connectors. Is there an appropriate ignition-switched connection available as I am reluctant to splice directly to the battery?
Old Mar 21, 2015 | 02:53 PM
Mr Jokster's Avatar
Mr Jokster
Well it should have both ignition and battery, so it has to go to the battery anyway. Either way, why are you reluctant to go directly to the battery? I have close to 300a connection hooked up to the battery, not to mention there are plenty of factory circuits with much more than 6a of draw. Splice anything, as long as you use a relay and fuse the wire, you'll be fine. BTW, the cigarette lighter is set for 10a, you can easily use that and as said, use a relay to distribute the power safely and correctly.
Old Mar 21, 2015 | 03:12 PM
Mike246's Avatar
Mike246
Thanks for your quick reply.
I am reluctant to take a cable from the battery through to the passenger compartment if it could be avoided and there is a take-off point more suitable.
The handbook makes mention of the power outlet in the cenre console with a warnng not to draw over 3.5 amps.
Malihassan
CT 200h Model (2011-2017)
Apr 27, 2019 06:31 AM
jednav
Feb 6, 2018 07:35 PM
tradosauru
Feb 10, 2016 06:30 PM
semar
Sep 2, 2015 12:45 PM
Robertcave
May 31, 2014 08:05 AM
