Is it safe to change the transmission fluid?
Old 03-02-15, 08:31 PM
bkos90
bkos90's Avatar
Default Is it safe to change the transmission fluid?
Hello everyone, I am new to the forums. Just bought a 2000 GS400 last week. i have a few questions..
The car has 195,xxx miles and i am debating weather or not to change the transmission fluid. I have no idea when the last fluid change was and the fluid isn't black but it does seem a bit muddy. I've had some horrible experiences with fluid changes on cars that are high mileage and had never had the fluid changed.
Have any of you done this before?
Old 03-02-15, 08:32 PM
RXGS
RXGS's Avatar
i think a drain and fill would be ideal
Old 03-02-15, 08:33 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
drain and refill
Old 03-02-15, 08:46 PM
maxx430
maxx430's Avatar
dont think there will be an issue if you just drain and fill.
Old 03-02-15, 10:43 PM
sam12345
sam12345's Avatar
Drain and fill, then add this filter to your tranny line that goes to radiator. Then drive 5k miles, drain and fill, drive another 5k miles, drain and fill, then another 5k miles drain, drop pan and clean pan and change internal screen. Fill and change the filter you added to line for a new one. Then you are set for 50k miles.
Share
TRNW E-Store TransProtector 3/8 Inline Filter<br>with hardware http://www.trnw.net/store/products.php?products_id=523 (Share from CM Browser)
make sure it's a steel filter not the cheap plastic ones
Old 03-03-15, 02:03 AM
lextout
lextout's Avatar
Just drain it from the tranny line going to the radiator,this will dump out around 5 quarts,disconnect the tranny line to the radiator, start the car in park for 5 seconds then turn off, this method is more efficient i think then just unbolting the nut on the bottom of the tranny pan, as only 1.8 quarts come out of that
DO NOT DO A COMPLETE FLUSH
colfax
08-25-18 07:25 PM
DMPesso
Performance
16
12-10-10 11:55 AM
chnk
Performance & Maintenance
11-16-10 08:06 PM
margarita
32
04-10-09 07:06 AM
jimbo22s
07-09-04 07:36 PM
Quick Reply: Is it safe to change the transmission fluid?
