Head lights Auto levelling system
Old Nov 16, 2014 | 02:51 AM
Hornet's Avatar
Hornet
Default Head lights Auto levelling system
Hi
The dashboard light for head light auto levelling system was glows all the time .
I had replace the computer levelling system along with headlight but what is happening now when I start the engine the indication light turn off but after 5 seconds it glows again that mean the system is not working
I don't know that to do ? Does the system need a programming or the head light need to adjust in order the system start working
Anyone had an idea
Thanks
Old Nov 18, 2014 | 12:41 AM
lextout's Avatar
lextout
Try yo disconnect the battery for 5 minutes then connect, maybe that helps. I used to live and work in dubai, do you know a good scrap yard there with gs400/ls430 parts???
Old Nov 22, 2014 | 08:12 PM
chicov8's Avatar
chicov8
it could be sensors (sensors are on lower control arms front and rear just not sure on which side)
Old Nov 24, 2014 | 08:32 AM
Hornet's Avatar
Hornet
Yes friend I know
There is a street in Sharjah full with scrap yard for lexus
Most of this scrap they imported from japan
Old Nov 24, 2014 | 08:34 AM
Hornet's Avatar
Hornet
The sensors are ok
I had checked it
What is acually happened when start the car the lights goes down and up for initial setting but after that it stops and the indicator light glows again
ZaxF
Apr 4, 2014 05:03 AM
jucytec
Jun 6, 2013 06:24 AM
GS4_Fiend
Apr 12, 2009 01:56 AM
