Coolant levels
Old Nov 13, 2014 | 01:19 PM
Marklopez's Avatar
Marklopez
Default Coolant levels
Alright so this may be a dumb question but we learn something new everyday right? on a cold engine my coolant reservoir tank sits empty. When it warms up it sits about half way between full and empty. Is it okay to just add more without a flush? If so should it be pure or does it need to be diluted with water. When should I add it and how much should I add. All awnsers are helpful. Thanks
Old Nov 14, 2014 | 12:10 PM
Marklopez's Avatar
Marklopez
Old Nov 15, 2014 | 05:50 AM
marshun's Avatar
marshun
your reservoir should have fluid in it when its cold. so put fluid in it
Old Nov 15, 2014 | 12:51 PM
offbad's Avatar
offbad
there are lines demarcating what should be the acceptable COLD and HOT levels of fluid.
Old Nov 15, 2014 | 03:02 PM
Neomoogle's Avatar
Neomoogle
Yeah it's not normal to have an empty reservoir tank at any temp. Also, don't put straight coolant in there, put a 50/50 mix.
Old Nov 16, 2014 | 02:57 AM
Hornet's Avatar
Hornet
When the engine is cold the coolant level in reservoir should be in cold and when the engine is hot ( normal working temp) the Level should be in hot
You can add either distilled water or coolant 50% consent ration
peterls
24
Sep 29, 2019 02:41 PM
Finn
Apr 13, 2014 05:35 AM
Stemmer
RX - 1st Gen (1999-2003)
Nov 15, 2012 02:33 PM
shikbas
Jan 11, 2008 05:18 PM
Herm
Maintenance
Sep 2, 2003 11:37 AM
