gs300 passenger headlight inoperable possible cause/fixes?
Old Apr 17, 2014 | 03:16 PM
kaosfive5's Avatar
kaosfive5
Default gs300 passenger headlight inoperable possible cause/fixes?
So passenger hid went out no biggie replaced it to find new unit not operating. So some more diagnostics led me to move the driver unit to the passenger to see if it was a bad unit that I had recieved. No dice, ive narrowed it to being that the red plug in is not delivering current to the hid and was interested in finding out if its a fuse or what I could do to further narrow the cause. If fuse, which one would i need and where amongst the many honeyholes would i find the culprit. Any help appreciated. here's the photo of the connector i was referring to.
http://imgur.com/azpcXWz
gs300 passenger headlight inoperable possible cause/fixes?-azpcxwz.jpg
Old Apr 17, 2014 | 04:22 PM
DosyBoy's Avatar
DosyBoy
Take a volt meter and put the probes in the red plug and see what u get, but my guess is your ballast is shot for some reason or another , u should have switched the good light to that side and that would tell u immediately what's wrong, my guess is ballast...
Old Apr 17, 2014 | 05:45 PM
kaosfive5's Avatar
kaosfive5
yea that's exactly what i did. i plugged in the unit that worked on the driver side, to the passenger socket and no dice. that's what leads me to believe that there's no current coming from the passenger socket.
Old Apr 20, 2014 | 06:07 PM
kaosfive5's Avatar
kaosfive5
bump, any suggestions guys?
Old Apr 21, 2014 | 12:56 AM
offbad's Avatar
offbad
use a voltmeter
Old Apr 21, 2014 | 04:38 PM
kaosfive5's Avatar
kaosfive5
thanks, a coworker of mine will be bringing one in tomorrow.
Old Apr 21, 2014 | 07:11 PM
tereck's Avatar
tereck
There's fuses for the single headlights. On the fuse box by the battery says left and right headlight. Check those
Old Apr 22, 2014 | 05:30 PM
kaosfive5's Avatar
kaosfive5
So did The volt meter got the expected .12 on Driver side light that is fully operational and got a .6 on the passenger side. So I know im not getting the amount of power necessary to the light but whats the next step
Old Apr 22, 2014 | 11:00 PM
rydellluy's Avatar
rydellluy
Old Apr 22, 2014 | 11:43 PM
offbad's Avatar
offbad
check the relay?
Dr. VIP
Jul 4, 2007 08:48 AM
Agent$mith
Lighting
Oct 24, 2005 04:14 PM
cialz
Sep 30, 2003 12:09 AM
