Diff Guru's!~ Anyone identify this LSD carrier?
Old 04-15-14, 07:15 AM
GSJake
GSJake's Avatar
Exclamation Diff Guru's!~ Anyone identify this LSD carrier?
I have my car at the transmission shop and they are telling me this is not fitting in the housing.
When purchased I was told it was from a JZS161 Aristo... there for should be plug an play with my diff housing?
Can anyone confirm this by these pictures of it in this thread....?
https://www.clublexus.com/forums/gs-...our-gs-10.html
Thank you for you help.
Jake
Old 04-15-14, 12:02 PM
GSJake
GSJake's Avatar
I just got back from the shop.. The factory carrier is MUCH narrower than the one I have?
https://www.clublexus.com/g/album/790184
Thoughts?
Old 04-15-14, 12:56 PM
GSJake
GSJake's Avatar
It seems as if my diff does not have the arched sided like this one?
https://www.clublexus.com/g/picture/790242
I hear what i though was a rumor that from 04-05 their may have been a different housing used?
Can anyone confirm or deny this?
Old 04-15-14, 05:50 PM
jwin
jwin's Avatar
if its too big than its probably the 6spd supra tt diff. How many bolts are on the Torsen LSD part? 12 or 10 bolt?
Old 04-16-14, 09:38 AM
GSJake
GSJake's Avatar
UPDATE:
I have been doing a TON of research in the last couple of days. Long Long story short..
The diff was the same unit until 2\03. Lexus then changed the design to the one I have (2004 and above).
Essential my diff is the same as the Gen3 GS430.
This new design is NOT compatible with the MK4.
I can order a TOM's unit which is the ONLY unit designed for the 3rd gen GS.. but not at $2,200.
http://www.tomsracing.co.jp/products....php?mprID=286
OR i can get a 98-02 diff.
Thoughts?
Old 04-16-14, 11:47 AM
MotoEvo
MotoEvo's Avatar
Wow, that is a bummer to hear. I think sourcing a 98-02 GS400 differential would be the cheapest route to go. I guess my only questions would be is if the driveshaft flange is the same, and if there is any difference in mounting locations for the bolts. Too bad you weren't local to me, as I have an extra GS300 differential.
Old 04-16-14, 01:27 PM
GSJake
GSJake's Avatar
The flange is different but I have the correct one on the other diff which i can swap out.
Bolt and mounting locations are identical. From what i can tell.. they just omitted the recesses on each side to angel in the larger LSD carrier.
I guess from a technical stand point Toyota thought it not necessary in a car that never offered a factory LSD unit??
Yea.. i agree. I ordered one from Euro Chop Shop.
Got it for $260 shipped out of a 99, your right.. I wish i was local!
Thank you for the offer!
GSJake
Performance
04-15-14 12:34 PM
Dew23
Performance
01-30-12 12:48 AM
INCLINEDI
Performance & Maintenance
21
01-22-12 11:22 PM
slowdiver
03-27-08 10:02 PM
Quick Reply: Diff Guru's!~ Anyone identify this LSD carrier?
