Not sure what you mean on 5&6. Could you elaborate a little more please. Like why zip tie. Thanks
i think he means when you put the boot through the shifter you fold the excess inside out to accommodate the shifter ****.. then you zip tie underneath so it doesn't get undone over time by shifting gears...
Thanks guys, That is a 2012 Rx 350 shift ****, what I mean is when you are about to put the shifter boot over the metal shift rod, flip it inside out FIRST, then put it down over the metal rod to where the threads END, ZIPTIE it tight on to the metal shift rod at the end of the threads is where u wanna go, flip right side in so the leather is showing the right way, and just install over the shift gate..
Pete I think we may need your diy build thread picture where u did this, I had to take a tip from the DIY guru of course!!
