can i bad TPS cause p0420 code?
Old Jan 15, 2014 | 10:32 PM
islexusred's Avatar
islexusred
Default can i bad TPS cause p0420 code?
hey guys just replaced all four o2 sensors and both flange gasket after each cat on my gs400 to get rid of the nasty p0420 code that comes and goes, in the past week or so ive been getting VSC OFF and CHECK ENGINE light and a p0120 code which is throttle/pedal position sensor malfunction, already ordered a TPS on amazon to fix that code. so can bad TPS causes p0420 code in anyway?
Old Jan 15, 2014 | 10:38 PM
mnewxcv's Avatar
mnewxcv
very unlikely. Fix the tps and hopefully be done with your CEL
Old Jan 15, 2014 | 10:48 PM
islexusred's Avatar
islexusred
well i was thinking the TPS was telling the ECM that i am applying more throttle than i really am. In that case, extra fuel would have been applied in result confuses the o2 sensor.....? maybe
Old Jan 21, 2014 | 04:13 PM
hungmc's Avatar
hungmc
check the ventilation hose and intke air hose.
Old Jan 21, 2014 | 10:17 PM
islexusred's Avatar
islexusred
how do those 2 cause the a P0420 code?
Old Jan 29, 2014 | 07:50 PM
hungmc's Avatar
hungmc
Default refer to "fuel too lean"
the causes to broken the "cats or O2 sensors" is pobably "fuel too lean". That will defer the system of fuel get the MAF too low but air intake actually entered more by other leaking way.
tsl95
Jul 5, 2020 02:14 PM
DeanWeen
GS - 1st Gen (1993-1997)
Oct 9, 2018 04:08 PM
BostonSC4
Jun 30, 2010 04:21 PM
nicos1
Oct 8, 2007 12:44 PM
squeekyM
Sep 26, 2006 07:36 AM
