Anyone ever remove tiptronic controls from 2gs steering wheel?
Old Aug 18, 2013 | 10:36 AM
LeXUsFeEVa's Avatar
LeXUsFeEVa
Default Anyone ever remove tiptronic controls from 2gs steering wheel?
Just purchased a Blackwood steering wheel from Japan. Apparently it's sold without the tiptronic controls pre-installed. Has anyone ever removed or replaced the stock tiptronic controls?
Any help or guidance is greatly appreciated.
Old Aug 18, 2013 | 10:57 AM
rgarjr's Avatar
rgarjr
are u going to use your current steering wheel connector or does the new wheel come with it?
Old Aug 18, 2013 | 04:45 PM
LeXUsFeEVa's Avatar
LeXUsFeEVa
Not sure exactly. From the pics and what lexus is telling me its just blank holes at those locations. Would have to relocate controls from current wheel and utilize existing air bag. The last steering wheel I purchased for this car was plug and play. (Re-used air bag) but after looking at the back of my stock wheel it doesn't seems as if there's an easy way to remove tiptronic controls.
Old Aug 18, 2013 | 08:49 PM
rgarjr's Avatar
rgarjr
Some wheels come gutted (without horn assembly, cruise control, etc) so u have use your existing ones. Others come with all that so it's plug n play.
Old Aug 20, 2013 | 03:52 PM
LeXUsFeEVa's Avatar
LeXUsFeEVa
Thanks for the response. The wheel I'm purchasing is gutted...that being said do you know how to remove the tip tronic controls? (Can't seem to take it off without cutting the stiching)
Old Aug 20, 2013 | 08:30 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
You can most definitely take them out. I have done so. Use a small flat head screw drive or pick in order to pry each button up. You will need to unpin the plug in order to be able to pull it out. If you want to wait I can try to put together some pictures for you.
Old Aug 21, 2013 | 07:25 AM
LeXUsFeEVa's Avatar
LeXUsFeEVa
If you could post pics that would be awsome! For as much as I spent on the wheel, I definitely want to get it done right!
Old Aug 26, 2013 | 09:40 AM
LeXUsFeEVa's Avatar
LeXUsFeEVa
Any update on photo reference?
Old Aug 28, 2013 | 09:12 PM
Iparkcars's Avatar
Iparkcars
I did the same thing and replace mine the little wires going to the e shifter had to be taken out of the connect I used a sewing needle to get the free from the connect put the shifters in the new steering wheel and reconnected the wires
Old Oct 17, 2013 | 10:58 AM
LeXUsFeEVa's Avatar
LeXUsFeEVa
so after a much long wait my wheel finally arrived. Thanks to all who responded but I am still unclear how to actually remove the e shift controls. Before I can disconnect wires I have to remove button first correct?
anyone local want to make some extra cash and transfer the internals of my old steering wheel to my new gutted steering wheel?
pm me or text me for faster response 310-773-8187
located in Orange County, CA
Old Oct 17, 2013 | 11:30 AM
mk2tmr2's Avatar
mk2tmr2
tiptronic
tip tronic
e shift
There ya go!! I was going to post a comment that Tiptronic is a registered trademark of Porsche and all that. But you figured it out on your own.
Good luck getting the buttons out. Sounds like it's completely do-able.
Old Oct 17, 2013 | 11:44 AM
1sWt2GS's Avatar
1sWt2GS
pics and price of steering wheel? how close of it is a match to the blackwood. been wanting to get one forever!
Old Oct 17, 2013 | 12:32 PM
LeXUsFeEVa's Avatar
LeXUsFeEVa
So I figured out how to pry them out. Now regarding the 2 wires it seems as if they're soldered together? Should I cut and re-solder?
Old Oct 17, 2013 | 12:33 PM
LeXUsFeEVa's Avatar
LeXUsFeEVa
Match is probably 7-8 out of 10. Came from Toyota Japan and was crazy expensive. My current Blackwood has a brown hue to it...the wheel itself doesn't have that but definitely matches the Blackwood. Ill post pics tonight
Old Oct 17, 2013 | 01:13 PM
sakataj's Avatar
sakataj
USDM and JDM blackwood have a different hue to them
