Replacing Door Weatherstrip
Old Jul 9, 2013 | 12:58 AM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Default Replacing Door Weatherstrip
Its time to start replacing the worn out and sun faded weatherstrip on the door... part number 67861 and 67862. Has anyone replaced this? Is it a easy DIY? i searched and only found the lower door molding but i want the whole entire weatherstrip as shown in the diagram. seems like it would just pop out?
Old Jul 9, 2013 | 01:11 AM
clos430's Avatar
clos430
It's pretty straight forward, you just have to remove the door check and line up the clips. Really pay attention to the way the old one sits in place before you remove it.
Old Jul 9, 2013 | 01:13 AM
tmf2004's Avatar
tmf2004
whats the door check? I figured something might have to come off on the door to install this.. Does the bottom have screws?
should i just go to dealer instead?
Old Jul 9, 2013 | 01:25 AM
clos430's Avatar
clos430
Wish I had pictures to show, but I found this that kinda explains it better.
https://www.clublexus.com/forums/gs-...-the-door.html
Old Jul 9, 2013 | 01:29 AM
clos430's Avatar
clos430
This is the door check.
Attached Thumbnails Replacing Door Weatherstrip-169955d1270421091-doors-swing-open-door-check.jpg
Old Jul 9, 2013 | 01:44 AM
tmf2004's Avatar
tmf2004
so your saying that needs to un bolted to work around correct?
thanks for the link... I see that u can buy LT and RT clips so i wonder if i should buy those as well.. Thomas said in that ink that clips come with the weatherstrip.. i emailed Sewell to find out
Old Jul 9, 2013 | 08:50 AM
clos430's Avatar
clos430
Yup just remove the 10 mm bolt. New clips do come with new weatherstrip should be a easy task.
Old Jul 9, 2013 | 02:23 PM
Riksgs808's Avatar
Riksgs808
It is very easy to do. It took me 15 minutes max. Mine had a little plastic cover over the 10 mm bolt though.other than that all the clips just fall into place. Just gotta push them in.
Old Jul 9, 2013 | 03:27 PM
tmf2004's Avatar
tmf2004
thanks guys.. i did confirm with Sewell before i read this thread and the clips do come with the weatherstrip.. thanks guys
Old Jul 9, 2013 | 10:08 PM
KAJmapper's Avatar
KAJmapper
Gosh I need to do that
Old Jul 10, 2013 | 04:58 AM
chichat's Avatar
chichat
how much the weatherstrip?
Old Jul 10, 2013 | 07:41 AM
tmf2004's Avatar
tmf2004
it was $90 each door on Sewell's website
Old Jul 10, 2013 | 07:01 PM
Alphaman19's Avatar
Alphaman19
I just ripped em outta a gs300 at my local bone yard. What? that door check comes off? Jeesh, I just snipped the weather stripping at the bottom and pulled it off. Oh well. Can't complain for only $5
DnJ90
Jul 22, 2014 03:29 PM
MIGS
Sep 28, 2013 02:13 PM
koksik
Aug 19, 2013 12:38 PM
ahmed24
May 8, 2010 03:38 AM
