Two Questions
Old Jan 6, 2003 | 05:01 PM
rkytop_bob's Avatar
rkytop_bob
Question Two Questions
I HAVE A 2003 GS 430 LOADED. I HAVE A COUPLE OF QUESTIONS I WOULD LIKE ANSWERED.
1. DO YOU'ALL THINK IT WOULD BE OK TO PLAY CD'S THAT HAVE BEEN COPIED FROM ANOTHER CD'S? THE OWNERS MANUAL SEEM'S TO SAY NO.
2. IS THERE ANYWAY THAT WHEN YOU STOP AND TURN THE ENGINE OFF, PULL THE KEY, THAT ALL DOORS WILL UNLOCK.
3. IF I HAVE TO TAKE IT BACK TO THE DEALER FOR THE LOCK PROBLEM WILL HE CHARGE. THE CAR HAS ONLY 1000 MILES.
THANKS SO MUCH FOR THE HELP.
BEST REGARDS.......BOB
Old Jan 6, 2003 | 05:17 PM
joeydingo's Avatar
joeydingo
Default Two questions
1) You can play recorded cds with no problem. They are indistinguishable to your factory system, unless recorded in MP3 or some other compression format. My only advice would be to use ones from a reputable manufacturer (TDK, Maxell, etc), as some of the "Brand X" ones can have problems due to poor quality.
2) I believe the car does not unlock when turning off the ignition for safety reasons. Your dealer should not charge you for confirming this, nor should they charge you if I am wrong and the car can be programmed otherwise. A good Lexus dealer (and most of them are) will do small freebies when you first buy the car to make sure you confirm you are 100% satisfied whenever Lexus has you fill out the customer satisfaction surveys.
Old Jan 6, 2003 | 05:20 PM
mooretorque's Avatar
mooretorque
Talking
It's not as if your CD player will eat copied CDs; give it a try.
As far as the lock problem:
1) Most dealers will spot you one CBEST adjustment, and your 1K service would be a good time to get it done but
2) if the doors lock, you are then locked in your car with the security system enabled; you'll have to unlock the driver's door to get out and when you open the door, your security system will activate. And then you'd have to lock the door again once you are out!!
Feel free not to use "CAPS LOCK"; we'll all respond just as fast to lower case typing.......
Welcome to CL; you've got the finest Lex in the line!!
Old Jan 6, 2003 | 05:23 PM
rkytop_bob's Avatar
rkytop_bob
Arrow
I NEED TO EXPLAIN THAT THE DRIVERS DOOR WILL UNLOCK WHEN THE KEY IS TURNED OFF AND REMOVED. I WANTED ALL DOORS TO UNLOCK. MY CHEVY TAHOE WILL DO THIS AND I LIKE IT.........THANKS.........BOB
Old Jan 6, 2003 | 05:30 PM
doug_999's Avatar
doug_999
Here is a link to the C-best options. No charge for the dealer to make these changes.
https://www.clublexus.com/forums/sho...threadid=23510
BTW, typing in all CAPS is considered shouting.
Old Jan 6, 2003 | 05:36 PM
rkytop_bob's Avatar
rkytop_bob
Lightbulb
i'm sorry for the CAP's. I had no idea. It won' happen again.
Best Regards.............Bob
Old Jan 6, 2003 | 05:54 PM
mooretorque
Red face
I'm an idiot (or illiterate).......saw "UNLOCK" and read "LOCK".
Either age, too many rocks in the pipe this morning or maybe I just need new glasses. Anyway, no problem with unlocking. My GS is programmed to function precisely as you describe except that the doors unlock when I put the car in "PARK".
Doh.
xhifer
Oct 15, 2016 07:38 AM
Joebootx
GX - 1st Gen (2003-2009)
Oct 1, 2015 02:38 PM
jhawkcole
Jul 8, 2014 12:42 PM
daryll40
Oct 15, 2007 05:41 PM
Taka
Sep 5, 2003 03:30 PM
