Starting Issue
Old May 28, 2013 | 08:48 AM
99GS400HP's Avatar
99GS400HP
Default Starting Issue
Hello CL, Its been a bit more than a month i have been having this issue. When i go to start my car, i get a click noise.. and its gotten worse to this day... i've checked my battery and connections and they are all good. Now is there something else i can check before replacing the starter? for example fuses? or is this just the starter, and it needs to be replaced? thanks
more information would be gladly appreciated
Old May 29, 2013 | 06:26 PM
GeorgeGS4's Avatar
GeorgeGS4
A few questions:
Does it start after it clicks?
Does jumping the car do anything?
90% chance it would be the starter motor from what you're saying
You could always goto autozone for a free battery load test and have them check the alternator for free but if jumping the car does nothin, it would be your starter. You could always try the old school "hit the starter with a screw driver" and see of that gets it goin. Good luck
Old May 29, 2013 | 07:24 PM
TxLexus400's Avatar
TxLexus400
i have a 98 gs400 and when i first got mine i had the same problem, the starter contacts is what it is, its a common issue on the 400's. the starter is located under the intake manifold, best bet id to order the contacts off of lexus/toyota and do the job yourself its not too bad just cramped room around it. i think theres a diy somewhere on here just search.
Old May 30, 2013 | 01:08 PM
99GS400HP's Avatar
99GS400HP
Originally Posted by GeorgeGS4
A few questions:
it takes 5-12 clicks to start the car, as in 5 - 12 tries to turn on the car, once it goes the starter sounds normal, i checked my battery and all was good, i just recently found a thread that replacing the solenoids and plunger will fix the problem? thanks!
Old May 30, 2013 | 01:09 PM
99GS400HP's Avatar
99GS400HP
awesome thanks! yeah i found the DIY and ive ordered contacts and plunger
Old Oct 3, 2013 | 06:48 AM
DreallDay's Avatar
DreallDay
Default Similar problem
Could you list the part numbers, think I'm having the same issue and want to get this replaced
GSmamba
May 1, 2018 05:48 PM
supra9398
Apr 27, 2017 11:15 AM
sYnOnYx
Dec 6, 2016 08:32 PM
OneJay
Aug 15, 2011 03:24 PM
mosesgolf
Jan 23, 2007 04:28 AM
