Quick question on starting problem..
Old Mar 9, 2013 | 12:21 PM
Redline442's Avatar
Redline442
Default Quick question on starting problem..
My wife has a 2000 GS400. She came out to go to work the other day and the car wouldn't crank. At first, I thought it was the starter, but it turns over. Just doesn't start. Tries to, just didn't run. After I charge the battery a while, it might crank and run, but just for a few seconds and dies. My question is this...Does it sound like a fuel problem or a alternator/ generator problem? The battery is only about a year old. Any suggestions would be greatly appreciated. I want to try to do it myself first, hopefully to save a few dollars and learn a bit more. Thanks!!
Old Mar 9, 2013 | 01:49 PM
rogzballz's Avatar
rogzballz
Bad gas, drop an Alla-seltzer in the gas tank. Jk don't really do that.
Air, gas, power ...
Air filter?
Add dry-gas to the tank.
If battery is full charged, it should run for a bit untill it is drained when the alternator is bad.
Check those things, follow back with update
Old Mar 9, 2013 | 02:32 PM
Redline442's Avatar
Redline442
Added a little fresh gas, cranked up. Stalled. Cranked again, ran fine, smoke coming out of the exhaust. Smelled like something burning. Recranked it a few times, no smoke, but still a lingering smell of burning out of the exhaust. BTW, thanks for the reply.
RedlexGs
Jan 20, 2016 03:49 PM
CPFMonkey
Dec 29, 2009 10:57 AM
cactusmole
Jun 10, 2009 09:24 AM
