All the brand name indsah receivers are the same size. None should have any issue fitting in any car, even the Nissan Frontier which has a metal suport beam running directly behind the dash. It only gives you a few mm of clearance but other then that fits great. Our GS has no issues. I have even fit an amp behind the installed indash. The Alpine KTP-445u tucks just to the right of the radio cavity. Fits perfect. Now those knock off units, those are all bad. The gps antenna and plug-ins stick out and you can run into issues. Stick with name brand and you can never go wrong... with car audio of coarse.
