Locked keys in the trunk
Old Mar 4, 2013 | 06:29 PM
abounly's Avatar
abounly
I had a single 12 box, and just pushed it till it fell and just hooked the keys.
Old Mar 4, 2013 | 08:01 PM
CHINCHIN's Avatar
CHINCHIN
Originally Posted by tom steele
just take out the rear switch in the dash remove the side from the lock and ground the wires together should pop it
This is way easier than removing the back seat. Unbolt the lower part of the dash, disconnect the harness going to the truck release button, use some electrical wire or even a paper clip and join the two pins on the connector together. I've had to do it a bunch of times on various Lexus cars.
Old Mar 4, 2013 | 10:56 PM
Globalinx's Avatar
Globalinx
I cant exactly remember the sequence of events. But one time I dropped the key in to a trunk while closing it. Therefore locking it there. I remember spending 1.5 hour on disassembling the lock mechanism underneath the dashboard in the dark, by feeling it. Can't remember what exactly I did, but I did get my keys out of the trunk.
Old Mar 5, 2013 | 03:31 AM
CHINCHIN's Avatar
CHINCHIN
Or if you are really cool with your lexus dealer, they will cut you a dummy master key from your vin and you can open the trunk. Basically and aftermarket key such as Ilco that will work all the locks but wont start the car since it is not programmed. Cost should be under 10.00
Old Mar 5, 2013 | 10:21 AM
rotor's Avatar
rotor
Got my keys out!!!
BTW is a total of 6 12mm bolts. 2 on the top behind the headrest, and 4 on the bottom of the back piece seat.
Ps: thank you for all replies
xxc34
16
Mar 28, 2019 07:21 AM
funcrusher
12
Mar 16, 2016 09:45 AM
lexusben
Jun 1, 2011 05:43 PM
melarainc
Jul 2, 2009 05:15 PM
jonyboyyy
May 1, 2009 09:09 AM
