Steering wheel not centered after alignment?
Old Apr 1, 2012 | 11:58 AM
Och's Avatar
Och
Default Steering wheel not centered after alignment?
I had wheel alignment done on my car after replacing tie rod. Everything aligned perfectly within spec, the car tracks perfectly straight, no pulling in any direction, but in order to go straight the steering wheel is off by a degree or two to the right. The guy that was doing alignment had the steering wheel centered, even used some sort of a clamp to hold it on center.
Any advice?
Old Apr 1, 2012 | 12:56 PM
try2fndmrk's Avatar
try2fndmrk
Maybe he did the alignment wrong. When I do alignments I would do the "bounce test" after I get the alignment within spec... Most of the time it would throw off the spec that was "good" and I would have to re-do it cause I probably didn't tighten something.
Old Apr 1, 2012 | 02:07 PM
Vegas's Avatar
Vegas
Take it back, he does have your wheels aligned but not while the wheel is straight.
Old Apr 1, 2012 | 02:19 PM
DosyBoy's Avatar
DosyBoy
Def take it back........
Old Apr 1, 2012 | 05:14 PM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
That really irks me when the steering wheel is not centered when driving. I'd take it back.
Old Apr 1, 2012 | 06:41 PM
Och's Avatar
Och
Gonna see if I can take it back this week. I'm a perfectionist freak, and it aggravates the living hell out of me when the steering wheel is off center, I literally can't concentrate on anything else when driving.
Old Apr 1, 2012 | 07:03 PM
xplosion79's Avatar
xplosion79
I had an alignment done today and had them redo it after I noticed the steering wheel wasn't straight.
Old Apr 1, 2012 | 07:17 PM
GS4_Fiend's Avatar
GS4_Fiend
I always sit in the car and hold the steering wheel straight when they adjust. Thats only if they let you.
Old Apr 1, 2012 | 09:31 PM
Temptation's Avatar
Temptation
This might not be the cause but just make sure your tire is not low on air ?
Old Apr 2, 2012 | 02:04 AM
YviE's Avatar
YviE
Yeah, they have to center the wheel before doing the alignment... happened to me too...
Johnhav430
Jan 24, 2019 05:12 AM
BC64
Apr 9, 2013 09:55 AM
marvinje
Jun 12, 2012 05:29 AM
garfull
RX - 3rd Gen (2010-2015)
Jan 20, 2011 02:25 AM
boobstar
May 6, 2007 09:26 PM
