PLEASEEEEEEEEEEEE make sure all your doors,trunk is shut tight. Another member had the same issue and his passenger door wasnt shut right. It can also be the door detecting it being open if the mechanism is bad, any lights on?
Just went and checked and there all no lights on everything is closed, but as I was checking I discovered that the trunk will not open with the latch inside the car, think that is related to the problem?
